The celeron will bottleneck the 270 like hell. At least get a pentium g3258. What is your budget and what is your currency?
CPU:Intel Core i3 3210 Mobo:MSI B75MA-E33  GPU:Intel 2500 HD Graphics  SSD:Adata SP600 128gb  HDD:Seagate 1tb 7200rpm
PSU:Corsair CX430   Case:Antec ASK4000bU3  Monitor:Dell S2240l 21.5 inch 1080p
https://linustechtips.com/topic/410668-build-planing/#findComment-5529141
CSGO is not demanding game, it will run on almost anything, could you tell me you budget or do you just want as cheap gaming PC as possible?
@Khosus/bliat/
This is under 400$ and will run CSGO at 1080p maxed out without a problem. (If you can get an i3 though  :))
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($49.99 @ Micro Center)
Motherboard: Gigabyte GA-H81M-S2H Micro ATX LGA1150 Motherboard  ($44.99 @ SuperBiiz)
Memory: Kingston 8GB (1 x 8GB) DDR3-1600 Memory  ($43.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX 750 Ti 2GB Video Card  ($129.99 @ SuperBiiz)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($38.99 @ NCIX US)
Total: $398.43
Generated by PCPartPicker 2015-07-19 06:54 EDT-0400
https://linustechtips.com/topic/410668-build-planing/#findComment-5529145
i would like a cheap pc but that it would run csgo very good atleast 80 100 fps, i have 600$ but i want to save some so i could buy a good monitor so i would want a pc around 400$
Well than this build is ideal for you, search youtube for G3258 750ti and take a look at the benchmarks, pretty impressive for the money ,definitely beats consoles :)
Total: $398.43
Generated by PCPartPicker 2015-07-19 07:16 EDT-0400
https://linustechtips.com/topic/410668-build-planing/#findComment-5529217
PCPartPicker part list: http://pcpartpicker.com/p/YWQ7bv
Price breakdown by merchant: http://pcpartpicker.com/p/YWQ7bv/by_merchant/
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor  ($68.99 @ NCIX US)
Motherboard: ASRock FM2A88M PRO3+ Micro ATX FM2+ Motherboard  ($48.98 @ Newegg)
Memory: Team Dark 8GB (2 x 4GB) DDR3-1600 Memory  ($42.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($48.89 @ OutletPC)
Video Card: Sapphire Radeon R9 270X 2GB Dual-X Video Card  ($124.99 @ Newegg)
Case: NZXT Source 210 Elite (Black) ATX Mid Tower Case  ($41.99 @ Directron)
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply  ($25.00 @ Newegg)
Total: $401.83
Generated by PCPartPicker 2015-07-19 07:08 EDT-0400
This should serve you pretty well.
https://linustechtips.com/topic/410668-build-planing/#findComment-5529232
