What price range and location?
Preferably cheap (i'm not too familiar with them) maybe i know there are some under 200 are they any good? (some look like they are over 10k)
Oh, and midwest USA
*EDIT: I want to cut vinyl pieces for the walls as decorations, cups, and on plexiglass and metal
The Vinyl Decal guy.
Celestial-Uprising  A Work In-Progress
https://linustechtips.com/topic/409870-vinyl-cutter/#findComment-5520030
I am looking for a vinyl cutter that is not too expensive I'd like it atleast 12inches by 12 inches for decals and be able to input from my computer. Any recommendations?
You can get a Silhouette Cameo starter bundle or vinyl bundle on amazon for around $230. I know it's a bit over your budget but it's the only one i have any personal experience with, so it's the only one i feel confident recommending. It's a pretty decent plotter, and the software isn't bad. (you have to turn your pictures in to vector files before it can cut them)
"LTT's official.."STOP. I promise you aren't LTT's official bagel eater or whatever. Trust me.
https://linustechtips.com/topic/409870-vinyl-cutter/#findComment-5520063
lol this was the one I was looking at
any recommendations on vinyl for my purposes?
https://linustechtips.com/topic/409870-vinyl-cutter/#findComment-5520073
