my friend and i are having an argument over the fact that he can  see some red discolouring on my monitor wen viewing it from a strange angle, he only sees the "red discolouring" in the bottom rigth corner while the windows 7 log in screen is up. i on the other hand only see some white blur while viewing from the same angle. (while viewing on any other white image he keeps saying that the white isnt brigth enough.)
My pc:
http://pcpartpicker.com/p/dvcw23
(Black Glacier)
My server:
Dual xeon x5679 processors, 24gb of ECC memory, Nvidia quadro 295 NVS and 48tb of storage.  (z600
https://linustechtips.com/topic/409805-asus-vn247h-problems/
Well it is a TN Panel, so you're bound to have a little bit of colour shift, as to why you're seeing different shades I have no clue, but tbh if when you use it it looks good and you don't feel like it's an issue then it's fine there is no problem lol.
But the colour shift is just how TN Panels are, they get colour shift, and IPS Panels get a slight 'grey shift' effect
i5 4690k | GTX 980Ti G1 Gaming | 16GB RAM | MSI Z97 Gaming 7 | NZXT Kraken X61 | 850 EVO 250GB x2  | 1TB 850 Evo NZXT Noctis 450 | EVGA 750W 80+ Gold
 Ducky Shine 3 TKL (Browns) | LG 34UC87C | Logitech MX Master ATH-M50x's + DT990 Pro's
https://linustechtips.com/topic/409805-asus-vn247h-problems/#findComment-5520910
FIXED IT!! (there was dust/smudges on my screen)
My pc:
(Black Glacier)
My server:
https://linustechtips.com/topic/409805-asus-vn247h-problems/#findComment-5520995
