Hello here are the values I'm getting from AMD CCC:
Activity: 0%
GPU Clock: 308MHz
Memory Clock: 1250MHz
Power: 0%
Temperature: 74C
Fan speed: 20%
There is something definitely wrong. My cooling is fine for the rest of my case, especially with a 4.2GHz OC for my i7 950. Has anyone else had these problems before with the same/similar card from AMD?
Note: I use two monitors
https://linustechtips.com/topic/409380-idle-extremely-high-r9-290-reference/
Activity: 0%
GPU Clock: 308MHz
Power: 0%
Temperature: 74C
Fan speed: 20%
     Must be old thermalpaste or bad airflow in the case or the fan isn't working.
NOW THATS CRAY CRAY
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
What are your gaming temps?  :wacko:
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
That's fine, take the card out and re-paste and remove dust.
you're best bet would be to clean out dust from the case and add new paste to the card
I have no idea, on how to apply paste to a GPU unfortunately, but I cleaned my case out last week there with a high powered air blower.
Is it that hard to search something? :P If you don't want to do this send it back for warranty if you still have it.
Here is the temps as of re-applying the thermal compound on the gpu itself.
Still quite high but better than before.
I'm sure that's the temps I got on mine. It's just a hot running card
FX 8350, Crosshair formula z, GTX 980Ti (reference), Enthoo Lux, XFX 750w PSU, 16GB Hyper x Fury, 120Gb SSD, 1TB HDD Samsung drive, 1TB WD Black
