Define R5 mount questions
Just wandering in this setup:
is the radiator a problem? The R5 doesnt have a proper intake around the ODD area so will it effect temps? Doesn't even look like it'll get air.
That's basically my only cercern i just want the top 3 closed, and 3 bottom drives..
https://linustechtips.com/topic/409275-define-r5-mount-questions/
Why not get a define S? I have 5 drives (2 SSDS + 3 HDDS) and all the cooling I could need with the top vents closed.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
same price
For a better case though...?
Project Tomahawk:
CPU: Intel Core i7 4790k
Motherboard: Asus Maximus VII Hero
CPU Cooler: Corsair H100i
Memory: 16GB Kingston HyperX Fury 1866 Mhz
GPU: Asus Strix RX 480
PSU: Corsair RM1000
Storage: 2x Western Digital 2TB Enterprise + 240GB Crucial M500 SSD
Case: Corsair Air 540
Additional: Cablemod C-Series black/red kit, SP120, AF140 and AF140 w/ red LED's all around
Project Frankenstein:
CPU: AMD FX 6100
Motherboard: MSI 970 SLI Krait Edition
CPU Cooler: Cooler Master Hyper 212 EVO
Memory: 8GB G.Skill Ripjaws X 1866 Mhz
GPU: MSI R9 280 3G Twin Frozr
PSU: Seasonic M12II EVO 620W
Storage: Western Digital 1TB Enterprise + 240GB Partiot Torch SSD
Case: Fractal Design Define S
Sheila (Server):
Dell R210:
CPU: Intel Xeon x3450
Memory: 12GB Crucial ECC 1600 Mhz
Storage: Seagate 3TB Constellation
Marvin (Server)
Dell R210ii
CPU: Intel Xeon E3 1230v2
Memory: 12GB Crucial ECC 1600Mhz
you have no airflow in the case. air needs to go in one direction, but you have intakes on opposite side. they work against each other and cancel each other out. the classic path is intake on the front and at the bottom and exhaut at the back and on top.
what are you talking about, wont it intake from the front and exhaust the heat from the back?
edit: I understand now, the image should have the back as 'exhaust', sorry
