Before you rant in the comments:
I am getting proper tubing
I have not had time to organize cables
Anyway, I just ran a full load test on my homebuild. My fans are going rather fast and the motors are on their way out. I loaded down it with prime95 and unengine heaven at the same time. My loop is laid out like this:
Pump -> double 120mm -> r9 390x -> triple 120mm -> i5 2500 -> res -V
Here are a couple photos (too lazy for a proper screenshot)
post-128204-0-38609900-1437107082_thumb.
post-128204-0-99622400-1437107102_thumb.
https://linustechtips.com/topic/409200-how-are-these-load-temps/
The temps are excellent! The 2500(k) is a great overclocker, helped my friend with a build including that and it's been at 4.2ghz ever since. Other than the HORRIBLE mess you have visually, it's great!
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
https://linustechtips.com/topic/409200-how-are-these-load-temps/#findComment-5511682
oh my gosh I wish I had the K version of the chip. The non K can only reach 3.7ghz
https://linustechtips.com/topic/409200-how-are-these-load-temps/#findComment-5511700
ahh that blows. hell tbh they're cheap. your motherboard deserves an overclocked cpu, so maybe even go for a sandy bridge i7. before I had my build I was going to grab a 2600k-2700k actually. They are still fantastic and very viable options for gaming.
https://linustechtips.com/topic/409200-how-are-these-load-temps/#findComment-5511756
The reason I didn't bother with cable management is because I will have to remove the entire setup to replace the fans, tubing, and wiring.
https://linustechtips.com/topic/409200-how-are-these-load-temps/#findComment-5513741
