So, i today finished building new pc and only thing left to do is install w7 pro to it.
question is how, i have it currently installed on this x51, and i would like to install the original w8 that came with the prebuilt pc,
and then just reuse this w7 pro on the new pc, how do i do this?
do i need to deactivate the current w7 install or can i just install w8 over it and reuse the code(w7) to new pc
https://linustechtips.com/topic/408837-help-with-new-pc/
just install win8 over your x51 and install 7 pro onto your new build and activate it online but there is an update on win 7 that you shouldn't install i forgot which one exactly but it's 1.2mb and by default it is unchecked.
https://linustechtips.com/topic/408837-help-with-new-pc/#findComment-5507534
