Hello everyone!
Im currently building myself a new pc.
Its a X99 Build in a CORSAIR AIR 240.
I was wondering if i will have any problems fitting 2 120mm rads in the front.
That is because i will have a Corsair 80i GT installed and im planning on getting an
AMD R9 Fury X.
Will both 120mm rads fit in the front of the case??
I NEED YOUR HELP! :D
https://linustechtips.com/topic/408631-will-my-gpu-fit/
-snipperinho-
this will work (only with a GT60 or 55), tough you'll need to put the bottom rad in an push/pull config. otherwise you'll have fitment issues with the part where the hoses come out of the rad.
EDIT: like this
https://linustechtips.com/topic/408631-will-my-gpu-fit/#findComment-5504531
