I am not very good at telling which psu is better than the other, so I need your help. My pc build is
http://pcpartpicker.com/p/TDjwvK
And I am looking at a couple different PSUs.
https://pcpartpicker.com/part/corsair-power-supply-cx600
https://pcpartpicker.com/part/xfx-power-supply-pro650wp1650snlb9
https://pcpartpicker.com/part/evga-power-supply-100b10600kr
Please help and tell me which psu would be best! Thank you!
https://linustechtips.com/topic/408307-power-supply-help/
EVGA 600b is the best out of the three
XFX is the best out of the three
(Thought it was the 550w XFX)
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/408307-power-supply-help/#findComment-5500539
Don't get corsair CX PSU's with gaming rigs, they're meant for office and light use.
get either EVGA or XFX.
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/408307-power-supply-help/#findComment-5500555
Well, could you tell me why? The person right before you said the xfx so...
They are both very reliable, the EVGA is a superflower I believe which is a company known for making superb power supplies. The difference is that the EVGA one has a bit more wattage which may be helpful when using a R9 390
I thought that was the 550w XFX my bad. The 650w XFX power supply would be best
https://linustechtips.com/topic/408307-power-supply-help/#findComment-5500648
Ok thank you for the replies!
https://linustechtips.com/topic/408307-power-supply-help/#findComment-5500674
Check the link in my sig for info on PSUs and which ones won't blow up your system. The XFX of all of those is much better than the others. Both the EVGA and Corsair are mediocre but that doesn't mean that all of each of those brand's PSUs are all terrible - they're all made by different OEMs and such.
https://linustechtips.com/topic/408307-power-supply-help/#findComment-5501392
