 So I have a case fan that seems like it's going dry. It's making a slight clicking noise every now and again (It's fairly queit, need to be next to it to hear). My question is, how long will it last before dying since I'm currently unable to buy WD40 or anything else. Uni taxes ._.
https://linustechtips.com/topic/407397-fan-lubrication/
Ask a friend or neighbor for some oil, cmon be creative.
https://linustechtips.com/topic/407397-fan-lubrication/#findComment-5489857
Usually fans don't just die that easily.
If the clicking noise just started than it will take usually a long time until it actually doesn't spin up anymore, if it even happens at all.
https://linustechtips.com/topic/407397-fan-lubrication/#findComment-5489861
I guess but still, how long can it hold out?
https://linustechtips.com/topic/407397-fan-lubrication/#findComment-5489871
-awkward pic-
Does that even exist? O_o
https://linustechtips.com/topic/407397-fan-lubrication/#findComment-5489879
Well, my case fan seems to be spinning fine for now. What's actually more worrying for me is that the PSU also recently started making a click/tick, I pushed on the center of the fan it seems to have become less frequent. It's only 3 weeks old ._.
https://linustechtips.com/topic/407397-fan-lubrication/#findComment-5489898
My mind went somewhere else
I-See-What-You-Did-There-Rage-Face-Meme.
Love cats and Linus. Check out linuscattips-fan-club. http://pcpartpicker.com/p/Z9QDVn and Asus ROG Swift. I love anime as well. Check out Heaven Society heaven-society. My own personal giveaway thread http://linustechtips.com/main/topic/387856-evga-geforce-gtx-970-giveaway-presented-by-grimneo/.
https://linustechtips.com/topic/407397-fan-lubrication/#findComment-5489944
-snip-
Okay, that's creepy xD
At any rate, I seem to remember Linus saying that Double Ball Bearings don't fail instantly and usually get loud/show signs before doing so.
https://linustechtips.com/topic/407397-fan-lubrication/#findComment-5489961
WD40 is not a good bearing lubricant.
https://linustechtips.com/topic/407397-fan-lubrication/#findComment-5489972
tumblr_static_how-to-draw-the-le-lenny-f
LinusFanTips
https://linustechtips.com/topic/407397-fan-lubrication/#findComment-5489988
-snip-
LinusFanTips
 That's starting to get creepy xD
https://linustechtips.com/topic/407397-fan-lubrication/#findComment-5490009
-snip-
lol
https://linustechtips.com/topic/407397-fan-lubrication/#findComment-5490038
At any rate, I guess that if it's so quiet I shouldn't worry about it randomly stopping :D
Thanks everyone.
https://linustechtips.com/topic/407397-fan-lubrication/#findComment-5490193
To add to this: it has a very low flash point compared to actual oil, like 50c. I used some sewing machine oil (flash point like 200c) in some noisey fans last year then gave them to a friend and replaced with better. They are still working and quiet.
I'll mention this too since you thought WD40 was a good fan lube, you peel the sticker off the back and pop out the rubber insert to lube it, don't hose down the coil from the outside.
https://linustechtips.com/topic/407397-fan-lubrication/#findComment-5491723
