you just undid your hose or what did you disconnect
I have a port on my res so what I was was place a small bucket under then open the port, if you don't have a small enough bucket you can make like a channel out of tinfoil what leads the fluid into a bucket.
blackshades on
https://linustechtips.com/topic/407388-drain-ports/#findComment-5489821
