Solid works Crash
Go to solution Solved by lani100,
Okay So i am helping a classmate with Solid Works x64 2014 and what happens is he will start the program, begin sketching then the program will "encounter a problem" and crash,  Does anyone know what this could be or have dealt with this themselves? he does not have his CPU overclocked so it is not that problem, he has it on a new lenovo laptop and i dont know the model.  I tried having him reinstall it, and my guess was that his cpu could be overheating and throttling but that is not the problem either.  So if anyone knows please share you ideas!
Enable Intel virtualization in the BIOS and check the ram usage in taskmanager.
Run the program as admin.
  • CPU: Fx-8350 || Mobo: Gigabyte 990FXA-UD3 Rev 4.0 || Ram: GSkill Ripjaws 16GB (2x8GB) || GPU: Sapphire Tri-X OC r9 290 || Case: Phanteks Enthoo Pro || Storage: Seagate 1TB (Main Storage), Samsung 840 Pro 120GB SSD (OS), Seagate 1TB external (backups/Media) || PSU: Raidmax 730 Watt || Displays: 2x 2x Acer 21.5" S220HQL || Keyboard: Razer Blackwidow Ultimate || Mouse: Mad Catz R.A.T. 7
https://linustechtips.com/topic/407098-solid-works-crash/
https://linustechtips.com/topic/407098-solid-works-crash/#findComment-5485882
okay ill have him try that
https://linustechtips.com/topic/407098-solid-works-crash/#findComment-5485906
and its just strange because it runs fine on my desktop (albeit that my desktop is a lot beefier) but i have to say solidworks as a program is just awful compared to AutoCAD or inventor
https://linustechtips.com/topic/407098-solid-works-crash/#findComment-5485949
Yup but it could also be software related so it's a bit early to say that.
https://linustechtips.com/topic/407098-solid-works-crash/#findComment-5485963
Yeah he changed the intel thing and is now trying to run it
https://linustechtips.com/topic/407098-solid-works-crash/#findComment-5485982
Since it's a new laptop I assume he uses Windows 8.1 if so he will need Solid works 2014 with sp1. Also try updating the gpu drivers and try to run the laptop in high performance mode.
yeah the first fix was succesful thank you!
https://linustechtips.com/topic/407098-solid-works-crash/#findComment-5486028
