So I'm assuming thats a "Hell yes, the Sennheisers will kick those Yamaha's ass"
Correct?
probably, if your an audio freak its a positive, the only thing I've heard that makes the difference is gold plated audio thingy that you plug into the jack; you could do better but Sennheiser is a very reputable brand for audio headsets/mics , you should notice a comfort difference and a audio difference
https://linustechtips.com/topic/407018-noob-audio-question/#findComment-5484959
Sennheiser Premium and a lot higher quality where Yamaha makes Piano's and musical instruments not high quality headphones and such >.>
Yamaha makes great studio monitors and also great headphones.
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
https://linustechtips.com/topic/407018-noob-audio-question/#findComment-5484984
