So i have spent some time looking into each part and i think i have a idea of what might work well but i need some help with the more in depth parts like will all the part be compatible and such.
this build is meant to be 1500$ CAD i did go a little over but thats fine since the monitor is also in the budget.
the PC would be mostly for gaming with small amounts of (3D Modelling) Solidworks and catia.
only extras that i need is a monitor no need for keyboard, mouse or headset.
So this is the link to the Build: http://ca.pcpartpicker.com/p/PzMWvK
Thanks for any help and suggestions in advanced
https://linustechtips.com/topic/406380-need-some-help-on-first-build/
At this point your build is all wrong especially with the amount of money you have.
Skylake is about a month or so out and the prices should drop on the parts you picked but they will also be outdated
your best bet if you need a PC is going with a 5820k and x99.
