if you know the BIOS manufacturer you can check the beep codes (google it)
It's most likely since you don't have the RAM installed
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/406299-pc-beeping-noise/#findComment-5475394
That will be because there's no RAM installed.
Gaming/Folding rig: Coolermaster CM 690 II Advanced White | MSI Z77A-G43 | Intel Core i7 3770k @ 4.4GHz | 10GB G.Skill RAM | Nvidia GeForce GTX 780 | Samsung 840 Pro 128GB | Seagate 2TB | Seagate 2TB | WD Blue 640GB | Cogage Arrow (Passive) | Thermaltake Toughpower XT 675w | Windows 10 Pro
Photography
https://linustechtips.com/topic/406299-pc-beeping-noise/#findComment-5475397
