Hello everyone,
I recently bought a new graphics card which is the (MSI GTX 970 Gaming 4G) and was wondering if I will run into a problem having this power supply (GIGABYTE SUPERB GE-P450P-C2) , do I need to upgrade it? And what am I looking for in a new power supply (with details please)?
Thanks a lot.
https://linustechtips.com/topic/405057-graphics-card-power-supply/
Hello everyone,
Thanks a lot.
yeah it'll be fine.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
yeah it'll be fine.
Well Thanks but I'm little confused now because others say it's not enough.
I think it doesnt have all the necessary connectors
Is it possible to just buy a PCI power connector and plug in into the 8pins?
1) Ratings: 80+, 80+Bronze, 80+Silver, 80+Gold, 80+Platinum, 80+Titanium
2) Amount of Wattage usually 750-850w
3) Brand Reputation
4) Price
What is enough ? What do I need exactly? And preferably link to the PSU I need. Thanks
80+Bronze would be the minimum for "high-end" hardware, but 80+ is fine for your needs unless of course you're looking to overhaul your build in the future
You'll probably need something right around 650w-750w
You can choose any PSU you want as long as it fits your price point or budget
an 8 pin is a pci power connector  so no
an EVGA GS 550w is perfect
