Can anyone tell me what the difference between these 2 K95's. I see the logo is difference but cant tell if the cheaper one comes with the hand rest.
http://www.scan.co.uk/products/corsair-vengeance-k95-rgb-backlit-cherry-mx-rgb-pro-gaming-mechanical-keyboard-sails-logo-limited-av
http://www.scan.co.uk/products/corsair-gaming-cgk95-rgb-cherry-mx-red-mechanical-gaming-keyboard
CPU: Intel i7 4930k 5Ghz RAM: GSkill Trident X 2400Mhz MOBO: Asus Rampage IV Extreme Black Edition  GPU: Asus Strix 1080ti OC 2067Mhz PSU: Corsair AX1200i Case: Coolermaster C700P
Cooling: Corsair H100i with 2 ML120s & 4 HD140s
 SSDs: 1.75TB Samsung SSD's + 10TB HDD'sOS: Windows 10 Insiders Build Fast Ring - Monitors: Asus PB287Q 4K  -  Mouse: Corsair Glaive RGB Keyboard: Corsair K95 Platinum MX Brown
Audio: Asus Xonar STX + Senn HD650
https://linustechtips.com/topic/403766-corsair-k95-difference/
One has the original TrampStamp logo, while the others has a sails logo. Don't go by the pictures though. They are stock pictures
That time I saved Linus' WiFi pass from appearing on YouTube:
A sudden Linus re-appears : http://linustechtips.com/main/topic/390793-important-dailymotion-account-still-active/
https://linustechtips.com/topic/403766-corsair-k95-difference/#findComment-5443977
One is RGB and the Other one is not
Both are RGB.
One has the older (and better) corsair sails logo, while the other has the newer corsair gaming logo.
https://linustechtips.com/topic/403766-corsair-k95-difference/#findComment-5443992
Well I mean they are both RGB tho.
¨Corsair Vengeance K95 RGB MX RGB Mechanical Gaming Keyboard¨
¨Corsair Gaming CG K95 RGB Cherry MX Red Mechanical Gaming Keyboard¨
Wanted Build: i5 4690K, Z97-A, Vengeance 16GB, Samsung 256GB SSD, 980TI, Phanteks Enthoo Evolv ATX
Keyboard: Blackwidow Chroma Mouse: G502 Headset: Skullcandy PLYR 2 Phone: Samsung S6 Edge Tablet: iPad 2
Investing in becoming a Logitech fanboi?
https://linustechtips.com/topic/403766-corsair-k95-difference/#findComment-5443997
Yea looks as though its the same but different logo and the Corsair Gaming one is just price gouging seems to be the same on many sites and corsair think its fine to launch a new line and up the price on the same keyboard. I'll get the older one
https://linustechtips.com/topic/403766-corsair-k95-difference/#findComment-5444061
