Ehi guys I have to choose a good vga for my new pc. I like very muche nVidia and in particular the gtx 670.Now I'm in doubt because it's come out the 770.What do you think I have to do?
thanks in advance.
CPU: DualCore AMD Athlon 64 X2, 2700 MHz (13.5 x 200) 5200+ | Motherboard:Asus M2N-XE | Ram: Kingston 2G-UDIMM x2 | HDDs : MAXTOR STM3320613AS+ Maxtor 6B200M0 | VGA : nVIDIA GeForce 9400 GT | Sound card : nVIDIA nForce 6100-400/405/420/430 | Monitor : Samsung 27'' | Power supply : Xfx 850W | OS : Windows Pro 7 64bit | Case : Corsair 600T
https://linustechtips.com/topic/40376-vga-max-400-nvidia/
You should consider a GTX 770 or wait the AMD 9000 series. If you think the 770 is abit of an overkill, you could buy a 670 and sli it later if you need the extra performance as the price of the 670 has decreased significantly. What is the resolution of your monitor(s)?
CPU: Intel core i5 4670k @ 4.4ghz  CPU Cooler: Noctua NH-U9B SE2 GPU: GTX 660 Motherboard: MSI Z87M-Gaming RAM: Corsair Vengeance Low Profile 2x4gb Black @1.6ghz Power supply: Corsair HX650 80 plus gold Storage: Adata 64GB SSD + Seagate Barracuda 1TB Case: Corsair Obsidian 350d
https://linustechtips.com/topic/40376-vga-max-400-nvidia/#findComment-522126
I live in Italy and the budget is not more than 400$ because I have to buy cpu,motherboard,ram and maybe dissi....
the configuration will be decided here
http://linustechtips.com/main/topic/40336-i-need-of-a-new-pcyesi-need/
https://linustechtips.com/topic/40376-vga-max-400-nvidia/#findComment-522131
it is what I've thought...
https://linustechtips.com/topic/40376-vga-max-400-nvidia/#findComment-522134
