Hi guys,
My rig is in a Corsair 300R.
post-233354-0-58004500-1436441963_thumb. post-233354-0-51564000-1436441967.jpg
I have a FX-8350 paired with Sapphire Vapor-X R9 280X tri-X.
PSU is the Corsair RM 750W.
Please suggest any budget fans for the fan slots and.
Also the fan configuration.
Also i might go with the H100i .
Should i leave the default fans that come with the case??
Please suggest.
Thanks in advance.
https://linustechtips.com/topic/403565-cabinet-cooling/
Get a few be quiet pure wings :3
Also, you don't need a h100i, but if you want one, go for it, any reasonable tower heat sink will do the trick though.
I would leave the default fans in, unless they make annoying noise etc. I would chuck them out personally, but I'm a silence freak.
System specs
  • Graphics card: Asus GTX 980 Ti (Temp target: 60c, fan speed: slow as hell)
  • CPU: Intel 6700k @ 4.2Ghz
  • CPU Heatsink: ThermalRight Silver Arrow Extreme
  • Motherboard: Asus Maximus Viii Gene
  • Ram: 8GB of DDR4 @ 3000Mhz
  • Headphone source: O2 + Odac
  • Mic input: Creative X-Fi Titanium HD
  • Case: Fractal Design Arc midi R2
  • Boot Drive: Samsung 840 Pro 128GB
  • Storage: Seagate SSHD 2TB
  • PSU: Be quiet! Dark Power Pro 550w
Peripherals
  • Monitor: Asus ROG Swift PG278Q
  • Mouse: Razer DeathAdder Chroma (16.5 inch/360)
  • Mouse surface: Mionix Sargas 900
  • Tablet: Wacom Intuos Pen
  • Keyboard: Filco Majestouch Ninja, MX Brown, Ten Keyless
  • Headphones: AKG K7xx
  • IEMs: BrainWavs S1
https://linustechtips.com/topic/403565-cabinet-cooling/#findComment-5441470
I hope that RM750 was cheap.
 My Buyer’s Guide!
Build:
CPU: Intel Core i5 4690K Cooler: Cryorig R1 Ultimate RAM: Kingston Fury White Series 8GB SSD: OCZ 100 ARC 240GB HDD: Seagate Barracuda 1TB Motherboard: MSI Z97S SLI Krait Edition Graphics Card: Powercolor PCS+ R9 390 Case: Phanteks Enthoo Pro (White) Power Supply: EVGA G2 750W Monitor: LG 29UM67-P 29" 21:9 Freesync Sexiness Mouse: Razer Deathadder ChromKeyboard: Razer Blackwidow 2014 Headset: Turtle Beach Ear Force XP400
https://linustechtips.com/topic/403565-cabinet-cooling/#findComment-5441541
Am in India bro  :) .
Any suggestions to the heatsink.
Going to overclock just a bit and game at 1080p.
I've had good look with the be quiet pure rock in the past, really high quality for what it costs, although I don't know what you'd be able to find in your country.
System specs
Peripherals
https://linustechtips.com/topic/403565-cabinet-cooling/#findComment-5441544
ill try finding one of those.
Fan Configuration?
Yup around 7000Rs
https://linustechtips.com/topic/403565-cabinet-cooling/#findComment-5441712
Fan Configuration?
Just standard, Front,side and bottom as intake, and rear and top as exhaust. CPU should be blow towards the rear or roof, up to you.
You don't have to fill all the fan slots, just fill as many as you like.
System specs
Peripherals
https://linustechtips.com/topic/403565-cabinet-cooling/#findComment-5441770
Will the fans get in the way of the GPU??
Nope, not a chance, there's plenty of clearance for a set of side fans.
System specs
Peripherals
https://linustechtips.com/topic/403565-cabinet-cooling/#findComment-5441807
