Most people will suggest the ugly Noctua ones (they're awesome fans!) so if aesthetics are not a problem they're the best. I chose Corsair SP120's for my Rad cause they're quiet, and look really nice. A lot of the time it's a preference thing / style thing. However most people either choose the Noctua ones or the Corsair ones.
Noctua ones are the: NFF-12
Corsair ones are the: SP120
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/403421-fans-for-radiator/#findComment-5439687
I got some fractal design venturi pwm hp-120 fans and they have been working great for me. they go as low as 600 rpm and as high as 1800 rpm and are relatively quiet with full rubber corners to absorb vibrations.
CPU: Intel 5930K - GPU: EVGA Nvidia GTX 980Ti SSCMotherboard: Asus X-99 PRO/USB 3.1 - RAM: 32GB HyperX Savage @ 2800mhz CL14  Case: Phtanteks Eclipse P400 Tempered Glass - Cooling: Corsair H100i V2 / Fractal Design Venturi Fans Storage: PNY XLR8 120 GB SSD (OS) + Seagate 2TB HDD (Games)
https://linustechtips.com/topic/403421-fans-for-radiator/#findComment-5440736
