Well you don't need much power for those games. Go with a Radeon 290x :)
amnerd  B) Linux enthusiast.
  • CPU: Intel i5 4690k @3.5ghz  Motherboard: MSI U3 Plus Z97 GPU: Radeon R9 270x 2gb OC HDD: WD Green 3tb SDDs: Samsung 120gb, Kingston V300 120gb Case: Fractal Design Define R5 PSU: Corsair V650 Fans: Corsair AF14 x4 CPU cooler: Hyper 212 EVO (Upgrading soon)
https://linustechtips.com/topic/403002-building-pc/#findComment-5433965
AMD will get you much more performance for your money
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/403002-building-pc/#findComment-5433972
If i go with AMD can I reuse my current motherboard which is Asus M4N68T v1 It has am3 socket i think
AM3 is a amd socket
https://linustechtips.com/topic/403002-building-pc/#findComment-5433989
Ok so then i can save money, i think i wont build it myself i will go to company which builds pc from parts that u say and take a bit of money for their work ;D
why I bet you can build a pc.
https://linustechtips.com/topic/403002-building-pc/#findComment-5434005
Meh, U know word - Parents :D
Confused. They don't want you to?
https://linustechtips.com/topic/403002-building-pc/#findComment-5434017
http://www.amazon.com/Asus-G20AJ-US006S-i3-4150-Windows-Desktop/dp/B00NMVC8C2/?
a bit of money for their work a bit of money for their work a bit of money for their work
https://linustechtips.com/topic/403002-building-pc/#findComment-5434023
He want to build a PC with 500 Euros!!!
The R9 290x is about 400 Euros.........
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/403002-building-pc/#findComment-5434034
i7 with 760!!!!!! worst PC ever
https://linustechtips.com/topic/403002-building-pc/#findComment-5434035
Meh i will try going and questioning them how much will they take for my pc if i cant afford it i will build it myself :D
https://linustechtips.com/topic/403002-building-pc/#findComment-5434068
i7 with 760 lol
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/403002-building-pc/#findComment-5434103
Guys im thinking i will go with Gtx 750ti (150 euros) my current motherboard and Amd proccesor and 8gb of ram is that fine?
Since you're recording and already have a mobo I would just go with a AMD processor like the 6300 or 8320
But get at least a 270X or 280 if you have the money 750Ti really lacks in power.
        Setup
https://linustechtips.com/topic/403002-building-pc/#findComment-5434114
http://www.skytech.lt/search.php?keywords=270X&x=15&y=14&search_in_description=0&pagesize=100&sort=5a&f=86_85
Which from these are good for money?
https://linustechtips.com/topic/403002-building-pc/#findComment-5434154
the GTX 750 is very outdated!!!
at least go for the R9 270x or the R9 280 around and less than 200 Euros!
They play all recent games at decent settings, almost full settings expext anti aliasing and filters!
https://linustechtips.com/topic/403002-building-pc/#findComment-5434159
I have the Asus R9 270x and it rocks :)
https://linustechtips.com/topic/403002-building-pc/#findComment-5434172
I can take asus one 2gb for 180 euros or asus 4gb for 210 euros what do you think?
https://linustechtips.com/topic/403002-building-pc/#findComment-5434175
Well it is you'r money, of course the 4GB is better :)
https://linustechtips.com/topic/403002-building-pc/#findComment-5434205
When i'm recording which part is used gpu or cpu?
Both, mostly cpu i guess
By the way, League of legend is CPU intensive, so you dont have to invest a lot of money on a GPU if you are a LOL addict....
https://linustechtips.com/topic/403002-building-pc/#findComment-5434235
