Hi everyone! I'm super new here! I've been looking a lot of linus video and I think I learnt a lot from him!
Lately I started having some problem with the audio of my Lenovo y50 70 : the sound starts randomly crackling while playing youtube videos or any streaming videos. It's TOTALLY random cause when I pass over the same point twice the crackling is gone but it does it again on other point of the video... The problem is still persistent when I plug in my headphone.... sometime I have the same problem even with downloaded videos... I've noticed that when I use "download mode" the noise shows less time than when I use the "elevated specs mode"...
Looking at the video linus did about sound card.... can it be that the sound is not working very well for electricity interference inside the motherboard?
thaaank you very much for your help!!! :D
https://linustechtips.com/topic/402159-audio-crackling/
Turn up the sound of your system and turn down the sound on the headset/Speaker itself, should make it better.
Build: GPU: MSI GeForce GTX 780 CPU: Intel i5 4690 MoBo: AsRock Fatal1ty H97 Killer RAM: Kingston HyperX Beast 16GB PSU: Seasonic 550W 80+ Gold Case: Corsair Obsidian 500R
https://linustechtips.com/topic/402159-audio-crackling/#findComment-5421870
could be interference or just a bad audio card. I've seen that often on Lenovos
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/402159-audio-crackling/#findComment-5421872
Have you tried it on just a set of speakers? Headphone wires are so easy to damage and are notorious for creating scratchy static noises. Especially on a random basis.
                  Did I help you to fix your problem or at least did offer somewhat valuable advice? Consider giving my post a "informative" or "thumbs up".
SYSTEM 2: Modded G3 case with Gigabyte GA-G33M-S2L, Intel E8600 (O.C to 4.2GHz.), 4GB GSkill PC8500, Nvidia 8800GTS (512M), Cooling provided by Scythe Big Shrunkin, HDD 1 = OSX 10.9.5, HDD 2 = Windows 7 Pro X64. (Placed 3rd in MacMod  of the year 2012) (For info see:  http://insanelymac.com/forum/topic/285641-and-the-winner-for-macmod-of-2012-is/
LAPTOP: Inspiron 1720, Modded BIOS, X9000 Core 2 extreme OC'ed and undervolted to 3.4GHz (windows only) , 6GB DDR2 800, 8600M GT, 1920x1200 Glossy display, Sigmatel Audio, 2 Kingston HyperX 120GB drives (1 with Windows 7 x64 pro & 1 with OSX 10.9.5) X9000 Processor World Record Holder since 02/2013 on Geekbench 2 : http://browser.primatelabs.com/geekbench2/search?dir=desc&q=x9000&sort=score
https://linustechtips.com/topic/402159-audio-crackling/#findComment-5422183
I will try also with speakers... but the main problem is that with or without headphone I have the same problem with the speaker of my pc.... since I usually use NO other speaker cause I don't have them .... what can I do?
EDIT : I tried also with speaker but it doesn't change anything! there still is the crackling
https://linustechtips.com/topic/402159-audio-crackling/#findComment-5423726
Download DPCLatency checker, run it in the background while you do your normal stuff and once it happens again, check it.
If it's a DPC issue, it will show on the program.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/402159-audio-crackling/#findComment-5440961
Hi! I have used that program! I've seen that when I have the crackling the dpc latency goes higher a lot! what can I do so? Over 2000
What are your specs?
https://linustechtips.com/topic/402159-audio-crackling/#findComment-5479833
it displays this message:
Some device drivers on this machine behave bad and will probably cause drop-outs in real-time audio and/or video streams. To isolate the misbehaving driver use Device Manager and disable/re-enable various devices, one at a time. Try network and W-LAN adapters, modems, internal sound devices, USB host controllers, etc.
but I cannot find which driver it is!
I always have the lenovo software displaying a update of w-lan drivers so I thought it was that... but every time I update it , it displays it again....
https://linustechtips.com/topic/402159-audio-crackling/#findComment-5532347
Okay, start the system in safe mode with networking, and try the tool again.
We can attempt to find out if it's the pre loaded software, or a driver causing the issue.
https://linustechtips.com/topic/402159-audio-crackling/#findComment-5535718
I'm right now in safe mode but the audio doesn't start and also the tool doesn't start . The tool gives me back this error: InstallDrv: StartService failed with error 0x0000043C . for the audio it says "one or more audio services are not in execution" not solved
EDIT: also with my headphone I cannot hear music
https://linustechtips.com/topic/402159-audio-crackling/#findComment-5545121
I have the same problem and im pretty sure its because I cracked a USB port back in the day by accidentally stepping on a cable. Try taking your headphones of the back of the PC and connecting it to a front port if available, that fixes the problem, a restart works too usually.
They say you are what you eat, but I dont remember eating a legend.
https://linustechtips.com/topic/402159-audio-crackling/#findComment-5546628
well actually it's not only a problem of headphone it's a general issue... lately has been a bit disappearing (or maybe I got used to it! *sad*  ) .... anyway I cannot plug the headphone in another port cause I have a laptop.... and the problem is persistant so a restart doesn't fix it ... but thank you
https://linustechtips.com/topic/402159-audio-crackling/#findComment-5580384
I had the same problem and this morning was even worse than usual. I was a little desperate to find a solution because I can't afford to buy a new laptop right now. I decided to run a few test with my anti-virus system and it told me that I had some updates that i had to do. I did them and I restarded my computer and now it works fine. I have no problems with my audio at all. I don't know if this can help you at all, but it worked for me.. so why not share it! Anyway I hope you can fix your computer
https://linustechtips.com/topic/402159-audio-crackling/#findComment-5582482
