Problem with installing Office 16 Preview
Solved by Beltboy,
You can't re-install to get another 3 months, the designed it so once your 3 months are up you need to purchase a copy, right now your in a situation where the old install isn't completely removed.
Do you have any office software installed at the moment? you could try manually finding any office files/reg entries left behind but this can be very dangerous if you don't know what your doing.
