so i hear once in a while this strange noise coming from my pc , so i checked into it , it seems that one of the fans for the gpu when i rotate it it makes a strange noise , i dont think its coil whine . the other fans are ok . just wanna make sure what is it .
ps: there is dust on the fans , is it cuz of that?
https://linustechtips.com/topic/402084-help-me-plz/
It can be because of the dust. try cleaning it and see if the noise comes back.
why is there dust in your PC? You should be ashamed :C
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/402084-help-me-plz/#findComment-5421115
what is the noise lol? make a video of it.
https://linustechtips.com/topic/402084-help-me-plz/#findComment-5421126
