I am a total noob when it comes to water cooling. I would like to know if these two items will work together or if their is a better pump also would I need 3/8 fittings or 1/4 fittings
1. https://shop.ekwb.com/ek-ddc-3-25-laing-ddc-3-25
2.http://www.frozencpu.com/products/9576/ex-res-157/Bitspower_Water_Tank_Z-Multi_250_Inline_Reservoir_BP-WTZM250P-BK.html?tl=g30c97s165
Also any tips are greatly appreciated  :)
https://linustechtips.com/topic/401706-please-help-me/
also since your Pump is 3/8 line you can just Buy 3/8 Fitting in the G 1/4 thread pattern for all your parts
Or you can Change the pump top and Pick whatever Line size you want. in all reality. 3/8 vs 1/2 tubing makes Zero difference.pick what you like best
https://linustechtips.com/topic/401706-please-help-me/#findComment-5416689
