So I am making an android app and I want to write a string to a file. The problem is that whenever I do that, the file is empty. I have checked and the string I input in the function is not empty. Anyway, here is the code responsible for the write operation:
    public void writeToFile(String text, String dir)    {        try        {            FileOutputStream out = new FileOutputStream(new File(dir));            PrintWriter fileOut = new PrintWriter(out);            fileOut.print(text);            out.close();            fileOut.close();        }catch(Exception e)        {                    }    }
MacBook Pro 15' 2018 (Pretty much the only system I use)
https://linustechtips.com/topic/401645-problem-with-android-app/
Grammar nazis are people too!
Treat your local grammar nazi nicely and he might teach you a thing or two. (Note that I'm Belgian and not a native English speaker.)
Chivalry isn't dead!
https://linustechtips.com/topic/401645-problem-with-android-app/#findComment-5422442
I fixed it! When I should have used File out = new File(directory, filename); Now it's all fine :D
https://linustechtips.com/topic/401645-problem-with-android-app/#findComment-5423615
