i have my h105 pump/waterblock hooked into the cpu opt fan spot and the lights on it arnt at full bright and not full power. is there a way to fix this? does it need more power? if so any way i could give it more power.
There are no lights on it. Sorry, there is, just checked.
If you need more power, you can hook it up to molex with an fansplitter Ek and noctua sells them. Probably others too.
https://linustechtips.com/topic/401288-h105-help-asap/#findComment-5410202
yes there are the corsair logo lights up and the pump is not at full speed on the cpu opt fan
I thought there was just the ring around the pump...
 My Buyer’s Guide!
Build:
CPU: Intel Core i5 4690K Cooler: Cryorig R1 Ultimate RAM: Kingston Fury White Series 8GB SSD: OCZ 100 ARC 240GB HDD: Seagate Barracuda 1TB Motherboard: MSI Z97S SLI Krait Edition Graphics Card: Powercolor PCS+ R9 390 Case: Phanteks Enthoo Pro (White) Power Supply: EVGA G2 750W Monitor: LG 29UM67-P 29" 21:9 Freesync Sexiness Mouse: Razer Deathadder ChromKeyboard: Razer Blackwidow 2014 Headset: Turtle Beach Ear Force XP400
https://linustechtips.com/topic/401288-h105-help-asap/#findComment-5410222
Maybe the pump is dyeing?
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/401288-h105-help-asap/#findComment-5410255
