Need help removing ad ware
Go to solution Solved by MaximusX,
So I was downloading cheat engine, and I somehow forgot to untick on of those boxes...
Now I have "Great Find" on my IE Browser and its horrible...
How does one remove this?
How did it go?
https://linustechtips.com/topic/401265-need-help-removing-ad-ware/
Why are u using IE??? Its so slow O_o
Anyway go to extensions and remove it
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
see if you can remove the great find temporarily by going to the extensions and removing it. i would first go to "uninstall programs" in control panel and see what looks fishy. after that, get malwarebytes to scan. after than get avast to clean the rest out. thats what i did for my friend's computer infested with viruses/malware, anything you can name. now it's as fast as when he bought it
Use adwcleaner also why IE?
Desktop 1: CPU: Intel Core i7 4770  GPU: Nvidia Geforce GTX 960 Ram: Crucial DDR3 2x8GB 1600 MHz  Storage: Samsung 850 Evo 250GB and Segate 1TB Hard drive  Desktop 2: CPU: Intel Pentium G3258  GPU: AMD R7 250  Ram: Corsair Vengance DRR3 2x8GB 1600 MHz  Mobo: MSI H81M-E33  PSU: Corsair CX430M  Case: Rosewill MicroAtx Mini Tower
Okay, i'll try that out. Brb.
Ill try that! I use IE because everything else doesn't work for me. FireFox seems to always give me adware (Just by going to google) Chrome always crashes on me.
So why do I use IE? Because it isn't slow, It isn't terrible, it just works.
At least I follow the forums CoC, Scrub.
Ok what ever works for you then :) though maybe you try opera http://www.opera.com.
Edit: Also try malwarebytes.
How did it go?
It went well! Malwarebytes took care of it :D
Nice!
