Is a 500w bronze PSU enough to power both a 970 and a 4790 (I'm going to OC the 970 a bit too.)
As far as I know it should be enough, just trying to reassure my worrywart of a mind
|CPU: Intel i7-5960X @ 4.4ghz|MoBo: Asus Rampage V|RAM: 64GB Corsair Dominator Platinum|GPU:2-way SLI Gigabyte G1 Gaming GTX 980's|SSD:512GB Samsung 850 pro|HDD: 2TB WD Black|PSU: Corsair AX1200i|COOLING: NZXT Kraken x61|SOUNDCARD: Creative SBX ZxR|  ^_^  Planned Bedroom Build: Red Phantom [quadro is stuck in customs, still trying to find a cheaper way to buy a highend xeon]
https://linustechtips.com/topic/400721-psu-help/
Bronze? It works but usually when you OC the CPU, but for GPU and CPU its better to get a Silver minimum, Gold to be safe. Just personal preference, do correct if I'm wrong anyone.
Main Rig
Case: NZXT H440 White | CPU: Intel Core i5-4690K @5.2GHz | CPU Cooler: Corsair H80i Hydro Series | Motherboard: MSI Z97S Krait Edition | RAM: HyperX Fury White & Black Series 16GB (4x4GB) OC to 2133MHz | Graphics Card: Zotac GeForce GTX 980 Ti ArcticStorm | SSD: Intel 730 Series 480GB & Samsung 840 256GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA 750W Supernova G2 80+ Gold | Display: BenQ XL2420G & Samsung S20D300 | Headset: Corsair 1500 | Mouse: Logitech G700S | Keyboard: Corsair Vengeance K70 Silver RED LED
 XENON Build:
Intel Xeon E3-1230 V2 @3.3GHz | Intel DZ68BC | Corsair Dominator Platinum 2x4GB 1866MHz | Kingston HyperX 3k 240GB | MSI GeForce GTX 680 | Fractal Design Define R4 Titanium Grey | Seasonic 520W 80+ Platinum Fanless
Office Build:
Case: Fractal Focus G White | CPU: i5-8600K | CPU Cooler: Cooler Master Hyper 212 Evo | Motherboard: MSI Z370-A PRO | RAM: Corsair LPX 16GB-2666 | GPU: MSI GTX 1060 6GB GAMING X | SSD: Kingston A400 240GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA BT 450W+ Bronze
Phone
iPhone XS Max 512GB Gold
https://linustechtips.com/topic/400721-psu-help/#findComment-5402109
What PSU? If it's what I think it is (low-end EVGA) then you should get something else. Otherwise it is plenty of wattage.
https://linustechtips.com/topic/400721-psu-help/#findComment-5402113
Very common question, lemme take the same quote that I out on my last post. I am guessing you are going with an EVGA 500W Bronze, which is horrible quality. You wouldnt want to fuel your Ferrari with Petrol someone is selling off the street would you? Same thing with a computer. Get this PSU it is OEM'd by a quality PSU manufacturer. P.S I stole that quote sorry  :)
http://www.newegg.co...N82E16817207013
https://linustechtips.com/topic/400721-psu-help/#findComment-5402120
? Ummm not how that works at all...
https://linustechtips.com/topic/400721-psu-help/#findComment-5402123
You about to get a metric shit ton of correction.
Prepared for it. Shoot away yo
Main Rig
 XENON Build:
Office Build:
Phone
https://linustechtips.com/topic/400721-psu-help/#findComment-5402211
Let's just say I would trust a seasonic 80+ bronze with a 10,000$ rig, build quality has nothing to do with efficiency.
My knowledge for PSU doesn't go as far, I just picked the amount of wattage I thought was reasonable. I look at Seasonic as a brand that produces very high quality build PSUs. The way I kinda compare things is, a Gold 500W ThermalTake is equivalent to a Bronze 500W Corsair? Idk it's just how I look at it.
Main Rig
 XENON Build:
Office Build:
Phone
https://linustechtips.com/topic/400721-psu-help/#findComment-5402506
Well I guess I should buy something better like a corsair RM but since it's the only psu on-hand I should just try it when the parts arrive and test it out. Then buy a better one when I get the money hopefully nothing goes horribly wrong.
oh and some of the others were a bit confused I bought a 4790 not a 4790k so I won't be doing any OC for this one.
this is for my brothers build so OCing the  gpu isn't necessary
https://linustechtips.com/topic/400721-psu-help/#findComment-5402514
Corsair RM is meh. For the ripoff price of the RM, you can usually get EVGA G2, XFX XTR, EVGA B2 which are all better.
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/400721-psu-help/#findComment-5405114
Don't forget the EVGA GS series, they are seasonic PSU's with a EVGA sticker on the side.
https://linustechtips.com/topic/400721-psu-help/#findComment-5405551
My PSU, I have the 550W GS and I'm picky about my PSUs.
https://linustechtips.com/topic/400721-psu-help/#findComment-5406167
