CPU Power Connector
Go to solution Solved by Redsun20,
Hi, I ordered a motherboard for a current build and just realized that the motherboard has a 8x connector for cpu power, but the power supply only has a 4x connector for cpu power. Will I need a different motherboard with a 4x connector, or should this one work fine? I am going to be using an i5-4460, and here is a link to the motherboard. http://pcpartpicker.com/part/gigabyte-motherboard-gab85mgaming3
Yes you can.Those pins are only for extra power, so I you only have 4 you're ok, but if you have a high power consumption chip (you don't) and you are overclocking, you are going to want an 8 pin
http://pcpartpicker.com/p/9DNjLk I like the night theme, it complements my dark basement. If you are reading this then you must also be a fan of the night theme.
01011011 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01001000 01100101 01110010 01100101 01011101
https://linustechtips.com/topic/399931-cpu-power-connector/
Yeah, you can use only 4 pins.
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
https://linustechtips.com/topic/399931-cpu-power-connector/#findComment-5391075
I had the same problem haha, my manual wasn't specific enough, iirc I just used an 8 pin that wasn't labeled CPU or I might've taken 2 4 pins (probably the latter, can't check at the moment, sorry).
https://linustechtips.com/topic/399931-cpu-power-connector/#findComment-5391084
“When life gives you lemons, don’t make lemonade. Make life take the lemons back! Get mad! I don’t want your damn lemons, what the hell am I supposed to do with these? Demand to see life’s manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I’m the man who’s gonna burn your house down! With the lemons! I’m gonna get my engineers to invent a combustible lemon that burns your house down!”
- Cave Johnson, founder and CEO of Aperture Science, in Portal 2
https://linustechtips.com/topic/399931-cpu-power-connector/#findComment-5391086
