Limit on wireless connected devices?
Go to solution Solved by vorticalbox,
I'm selling a WD Mynet 900c 2TB storage outer on Ebay, and a guy messaged me asking how many devices he can connect to it via wifi. Is there such a limit? I thought you could have as many as you want (within reason) he said, for example that apple airport express can manage 50 devices at once, which sounds like an apple made up number because it isnt a multiple of 8.  What should i tell him?
most routers are set to give ips from 192.168.1.2 ~ 192.168.1.255 giving 253 devices. not hard to config it should you need more than 250 devices...
STEAM NAME: JewishBacon GPU  Sapphire dual x R9 280x OC edition CPU core i7 4770k stock speed COOLER H100i  CASE Fractal R4 Window Black  MOBO MSI gd-65 gaming Storage 1TB WD Blue drive, 1TB Samsung 7200 rpm, 120 GB OCZ SSD, 64 GB WD Blue ssd  RAM 12 GB @ 1600 Ghz kingston RAM  MiscNZXT HUE, disk read/write, 2x 21 inch 1920x1080 monitors
https://linustechtips.com/topic/399817-limit-on-wireless-connected-devices/
ask him how many does he want to connect lmao?
It shouldn't be a problem.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
