My power supply is CoolerMaster V650.
On the packaging it says:-
Input voltage 100-240 Vac
Input range - Full Range
Input current- 9-4.5A
Input Frequency- 47-63Hz
Will this POWERSUPPLY provide enough power to my computer when run at a voltage range of 100 to 240V ? Is that what those specs say? Please be sure of your answer because my system might get damage from this.
Thanks
I've attached a picture
post-224959-0-17918700-1435929323_thumb.
post-224959-0-65875300-1435929351_thumb.
https://linustechtips.com/topic/399657-input-voltage-for-powersupply/
The power supply requires 100-240VAC to function meaning you can use it anywhere in the world.
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
...Will this POWERSUPPLY provide enough power to my computer when run at a voltage range of 100 to 240V ?...
That depends entirely on how much power your computer needs but it will output its stated specs if its within its stated input specs.
The PSU is fine whereever you plug it in.
Just make sure your PC doesn't pull more than 650 watts (als long as you only have one GPU you are fine)
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
