Few tricky questions
Elevation helps with there being less dust as well as being a tad cooler in some cases. Positive air pressure, more air intakes, is also better to keep dust out, as long as the intakes are filtered, as this prevents dust from coming in through the nooks and crannies
A Floating PSU is one where either pin on the plug can take plus or minus. Think of it like putting a single battery in a small flashlight, or plugging in your phone charger.
EDIT: A grounded PSU is basically something that saves your butt, as well as your PC's lovely circuits, from having a nasty experience with electricity. The grounding wire goes out into your house, separate from all other wires, out of your house, and physically into the ground via a rod. At least that's what my teacher told me in my basic IT class.
