Penguins or something random
(Main) Liquid Shadow V3 CPU: 5960x@ 4.7, Mobo: EVGA X99 Classified,RAM:G.Skill 16Gb 2666 ,GPU: 2 GTX 980Ti ClassifiedsPSUEvga Supernova 1000G1,Storage: Sandisk Ultra 2 480gb, WD Blue 1tb x3Case: Cooler Master Cosmos 2 25th Anniversary Edition
Liquid Shadow V1 CPU4790k@ 4.7, Mobo: MSI Z87X-Power,RAM:G.Skill Sniper 16Gb OC@1866 ,GPU:  2 Sapphire 290x's watercooled, PSUEvga Supernova 1000G1,Storage: Sandisk Ultra 2 480gb, WD Blue 1tbCase: Cooler Master HAF X
Extra Rig: Cpu: 4790k@4.7, Mobo: MSI Z87X-Power, Ram: 32Gb Corsair Vengeance/G.Skill Sniper,  GPU: 3 GTX Titans, Psu: Evga Supernova 1300G2, Storage: Case: Cooler Master HAF X
(First Rig)The Enforcer: CPU: FX 8350@ 4.6,Mobo: Gigabyte 990fxa-ud3,RAM: HyperX 8gb @2133,GPU: Diamond Multi Media r9 290,PSU: XFX XTR 750, Storage: Adata Premier SP550 480gb, Case: HAF 912
Peripherals Razer Naga Epic Original, Razer Deathadder,Logitech G910 Orion Spectrum, Logitech G13, HyperX Cloud
https://linustechtips.com/topic/399554-storage-help/
I want to replace the storage on my pc and i cant decide between a Samsung 850 evo 500gb and a Wd black 2 tb or A-Data premier pro 256gb, and WD black 3tb. I have a lot of games, music, Microsoft word, and other things. I plan to keep the drives for a while.
Thanks
850 evo- http://www.amazon.com/Samsung-2-5-Inch-Internal-MZ-75E500B-AM/dp/B00OBRE5UE/ref=sr_1_2?s=pc&ie=UTF8&qid=1435913953&sr=1-2&keywords=samsung+ssd
Wd 2tb- http://www.amazon.com/Black-Performance-Desktop-Hard-Drive/dp/B00FJRS628/ref=sr_1_2?ie=UTF8&qid=1435913883&sr=8-2&keywords=wd+black
A-Data ssd- http://www.amazon.com/ADATA-Premier-Pro2-5-Inch-Synchronous-ASP900S3-256GM-C/dp/B007RHT4K6/ref=sr_1_2?ie=UTF8&qid=1435913926&sr=8-2&keywords=adata+ssd
Wd 3tb- http://www.amazon.com/Black-Performance-Desktop-Hard-Drive/dp/B00FJRS5OW/ref=sr_1_4?ie=UTF8&qid=1435913883&sr=8-4&keywords=wd+black
Hey Pokemonking81,
The most popular and useful combination for desktops is a pure SSD with a separate HDD. I'd choose a big-enough SSD for the OS and all the demanding applications and games that would benefit from the faster transfer speeds and shorter access times and go with as big HDD as the budget allows for everything else. WD Black is a great drive designed for performance and durability. If you need a larger drive for simple storage and backups with no need of faster access times or high transfer speeds, I could suggest checking out WD Green: http://products.wdc.com/support/kb.ashx?id=JGhF2R
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/399554-storage-help/#findComment-5386238
