Hi,I have WD Blue 500GB drive.....Now I have 7 partitions......(C〓Windows Drive,E,F,G,H,I,J)
Sorry for extended paritions......
Now I want to Repartition Drive C and E when reinstalling Windows...Can't do it other time Because C have the windows installed...So how do I repart the Drives C and E....?(C and E are both 30.2GBs Drives)
Intel i3-4150 3.50Ghz | MSI B85M-G43 | HyperX Fury 8GB 1866Mhz x1 | Intel HD 4400 | WD Caviar Blue 500GB , Samsung 160GB | Odyssey 450W | AOC E950Sw 18.5In | Windows 10 Pro | Zebronics Armour 2
https://linustechtips.com/topic/398863-partition-problem-repartioning/
Hey Dencel :)
A screenshot of My Computer and Disk Management would be helpful.
Once you have the OS installed, C automatically becomes your default boot partition. You can re-size it, but it is not advisable as you can corrupt some of the boot files and cause Windows to crash and not boot again. You might be able to do that after you do a good defragmentation and reduce the size of the partition. You can extend it as much as you can, this shouldn't harm the files.
For the rest of the partition you shouldn't have problems doing so from Disk Management. :)
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
