Need some help on choosing a new case
Grem0
Hey all,
My current case at the moment is falling apart and was cheap and I think its time for a new one.
I have been looking around and have found 2 really nice cases that I feel will be suitable for my build
I just want to know which one to go for and why
These are the two contenders
NZXT H440 (Mid Tower):
http://www.amazon.co.uk/NZXT-H440-Tower-Window-Quiet/dp/B00HVZIXDI/ref=sr_1_2?ie=UTF8&qid=1435824577&sr=8-2&keywords=nzxt+h440
NZXT S340 (Mid Tower):
http://www.amazon.co.uk/NZXT-CA-S340MB-GR-Source-Midi-Tower/dp/B00RN3SJW8/ref=sr_1_1?ie=UTF8&qid=1435824568&sr=8-1&keywords=nzxt+s340
Thanks all
I own the H440, I just ordered today a new Corsair 760T because I need some more space for my system. I'd say go with the H440 between those two, but if you need some more space get something like the 750D: http://www.amazon.com/Corsair-Obsidian-Performance-Tower-CC-9011035-WW/dp/B00EB6O4N8/ref=sr_1_1?ie=UTF8&qid=1435825075&sr=8-1&keywords=750d
Ok thank you. I dont need a lot of space the only things that take up quite a bit in my case is my 140mm watercooler (Corsair H90) and my gtx 770 4gb but they should be alright in there. If im not mistaken this does support 140mm radiators right?
Yes you can easily install a radiator(s).
Front - 2 x 140 or 3 x 120mm Top - 2 x 140 or 3 x 120mm Rear - 1 x 140/120mm
Source: http://support.nzxt.com/hc/en-us/articles/202488364-What-Can-I-Fit-Into-An-H440-
