So I was looking at thermal pastes for my h110 because I had to swap it out for my stock cooler for demonstration purposes to my family. Any way I am an extreme overclocker and I keep my 3770k at 4.8 ghz and sometimes over and I was wondering which is the best thermal compound to use; arctic silver, ic diamond, etc. and are there any other advantages to using that verses other compounds besides heat transfer.
My system- I7 3770k (4.8ghz), Asus Maximus V Extreme, Corsair H110, Windows 8 Pro, Gigabyte HD 7970, Silverstone Strider Gold Evolution 1200w, Corsair H110, Corsair Vengance 2X8gb 1866 (OC2133), Samsung 840 500gb, Western Digital Caviar Black 2TB, and all housed in a NZXT Switch 810.
https://linustechtips.com/topic/39805-h110-thermal-compound/
I personally use MX-2 from Arctic Cooling, but I also have a couple of tubes with IC Diamond. Both are great options and have their advantages and disadvantages
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/39805-h110-thermal-compound/#findComment-513723
IC diamond, but it's not going to affect anything that much no matter what TIM you use.
CPU: i5 4670k • Cooler: Corsair H100i • Motherboard: MSI Z87 MPOWER • RAM: Crucial Ballistix Elite 2x 8GB • Storage: Samsung 840 250GB SSD, 2x WD Red 3TB • GPU: EVGA GTX 780 3GB • PSU: Corsair RM750W • Case: Corsair 750D • Mouse: Razer Naga 2012 (I actually use the thing for productivity/media buttons) • Keyboard: Ducky Shine 3 w/ Browns - Green LED • Monitor: Asus PB278Q 27" 2560 x 1440, ASUS PB238Q 23" 1920x1080 • Lighting: 2m NZXT Sleeved Blue LED Strip • pcpartpicker.com/p/3cHfZ
https://linustechtips.com/topic/39805-h110-thermal-compound/#findComment-513745
Just mix your own, I did this!
I call this IC diamond green edition. Green for extra eco-friendly.
[spoiler IC diamond green]
(totally not recommended.)
I actually don't use this stuff, I am sure it will kill you and your CPU.
How did you make that?
https://linustechtips.com/topic/39805-h110-thermal-compound/#findComment-519940
Yeah I am going to have to say ic diamond.
Desk: monitors 3x Asus VE248h(eyefinity), Keyboard Cm Strom Trigger(mx red), Mouse Corsair m65, Headset Audio Technica ATH-M50
Black Friday 2013 Build: i7 4770k, Gigabyte Z87X UD5H, 16gb Corsair, Msi R9 290, Corsair Axi 760, Corsair 750D, 2x intel 530 240gb ssd, 2x Seagate 400gb
Older Machine amd x640, msi 760g mobo, 8gb gskillz, Sapphire 6870, Corsair hx650, Cooler master haf 922, ocz agility 3 120gb ssd || HTPC: i7 3770k, shuttle xpc z77, 16gb gskillz, Asus GTX 650 ti, intel 120gb msata ssd
https://linustechtips.com/topic/39805-h110-thermal-compound/#findComment-520015
Arctic Cooling MX-4 is good but as I have said before that shit is like glue.
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
https://linustechtips.com/topic/39805-h110-thermal-compound/#findComment-520175
