Not if any metal is touching anything on the motherboard.
Follow the instructions. If the backplate is made of metal you don't want it to touch the back of the motherboard. Are you sure it's compatible with your socket?
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
What socket?
CPU: Intel Core i7 3770K  CPU Cooler: Corsair H100 (2x SP120 Quiet Edition)  Motherboard: ASUS Sabertooth Z77  RAM: Corsair Vengeance 8GB 1866MHz  PSU: Corsair AX850  GPU: EVGA GTX 670 FTW 2GB  SSD: Samsung 850 Evo 500GB
I Just installed one of these yesterday. one of the backplates is for intel the otherone is for amd. u pick the one u have and put the bolts in the front and the the backplate. the u use the plate that cross over eachother and put it in the posistion where it lines up with the whole on your motherboard
I only had one backplate, it was a old revision, ill drop my computer off at the local store and see if they can get it to fit, if not we will see other options
