HyperX Cloud 2
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/397888-best-headset-for-100/#findComment-5364279
hyperx cloud 1/2
one half lel
https://linustechtips.com/topic/397888-best-headset-for-100/#findComment-5364283
Boring, low quality.
Do you own one?
https://linustechtips.com/topic/397888-best-headset-for-100/#findComment-5364384
Get one of these for better quality and sound.
Philips SHP9500 with V-Moda Mic
Takstar HI 2050 with ModMic
can you plug the vmod mic into the philips? and do i have to plug in two wires into my computer?
https://linustechtips.com/topic/397888-best-headset-for-100/#findComment-5364385
$100 HyperX II
If you don't use the USB sound card (pop hiss disconnect) and you use a better mic you'll have this:
$45 Gemini DJ HSR-1000 (closed can = better bass) or $47 Takstar HI 2050 (open can = better gaming)
$30 VModa / $43 Mod Mic
$75-91
Cost's less, more reliable.
or upgrade with  $65 Philips SHP9500 (open can = better gaming) and a VModa/Mod Mic
https://linustechtips.com/topic/397888-best-headset-for-100/#findComment-5371595
