Possible CPU Bottleneck?
Go to solution Solved by Johannes_Lazor,
Nah, It should be good enough. I would recommend overclocking though.
And change the PSU, I would recommend a decent 550 watt PSU.
FSP group is not very high quality, It is decent for use in a office computer though.
I want to upgrade my Nvidia GTX 750ti to a GTX 960. I was wondering if my current AMD athlon x4 860k would bottleneck the 960. If so, what CPU should I upgrade to?
"Sometimes when you innovate, you make mistakes. It is best to admit them quickly, and get on with improving your other innovations" -Steve Jobs
https://linustechtips.com/topic/396269-possible-cpu-bottleneck/
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/396269-possible-cpu-bottleneck/#findComment-5345426
Yea I overclocked mine to 4 GHz
https://linustechtips.com/topic/396269-possible-cpu-bottleneck/#findComment-5345435
