Simple or not ? Q
Solved by Mighty_Miro_WD,
Hi there @pix-!
I personally would prefer the second option because with that you'll have enough space for apps and games on the SSD, and plenty of space for mass storage as well. Furthermore, you can also install and run games from the HDD since the only benefit from running them on SSD speeds will be the faster loading times which will be a big plus for open world games and such that have to load often and load in objects.
Hope this helps and feel free to ask any questions you may have!
Cheers!
