Hello all,
I'm building a PC and I've already made all the decisions for specifications and what I will get, I was originally planning the 240 but it turned out a little to tight for my card and so I went with the 540, which was too big. Finally, I settled the Corsair 350D and it seems just right, weighing in at 6.02 kg.
I'll be using this pc for travelling so maximum weight can be 9-10 kg.
These are my specifications:
Corsair 350D Windowed
Asrock Fatal1ty X99M Killer
i7 5960X
WD Black 2TB
Samsung 850 Pro 512GB
Corsair DDR4 LPX Vengeance Red 32GB (4X8GB) 3000Mhz CL5
Corsair H105
Corsair SP120 Quiet Edition (x3)
Corsair Professional Cables Type 3 (red)
Corsair 24-Pin Cable (red)
Arctic MX-4 Thermal Paste
Asus USB-AC56 Wi-Fi card
MSI Geforce GTX 980 Ti Gaming 6GB
The only thing I could find is the weigh for the case, so if anybody would help me estimate about how much kilograms this build would weigh, and if it would weigh more than 10 what could I do to reduce the weight.
I'm planning on adding another 2TB HDD and 980 Ti in the future, but right now I need to travel with this PC so I will stay with one.
If this all works out and it's sorted out, I promise a detailed LinusTechTips build post and PCPartPicker post with a ton of good quality pictures and description.
Cheers
https://linustechtips.com/topic/395826-ultimate-matx-x99-build-help/
