I went into the options.ini and searched for my city pressed enter and no results showed up. Are there any other ways to change the weather code.
Did my post help you? Then make sure to rate it!
Check out my post on symbolic links! || PSU ranking and tiers || Pokemon Thread
https://linustechtips.com/topic/395762-rainmeter-enigma-location-not-changing/
Those weather skins have always been glitchy for me too :( Trying to find a fix without having to rewrite code.
I could not get the location on a single skin working w/o changing the code so I decided now to use them for that.
Can you show me the modified code? So I can implement it into my own skins.
I did that on older themes that I had and in the meantime I reinstalled Windows so don't have the codes sorry. Since then haven't bothered. Just to point out, I was able to modify the code successfully only 2 times, wouldn't work all the times even if I killed myself.  -_-
The ability to google properly is a skill of its own.
Okay, that's fine :)
