Switches
Go to solution Solved by Giteau,
And wich of them has the best feeling and is less noisy ?
Razer Green = Cherry MX Blue (feel & sound the same)
Razer Orange = Cherry MX Brown (feel & sound the same)
MX Blues and MX Browns both have a tactile bump, but the Blues are much louder as they have a clicking noise.
(Just Youtube Cherry MX Switch comparisons)
Hei mates,
Yesterday I created a topic http://linustechtips.com/main/topic/392203-mechanical-keyboard/ where i wanted to know more about mechanical keyboards and what should i get. I said that i dont know how mechanical keyboards are and i cant view the switches in any shop, but today i found a store with "Razer Blackwidow Chroma" so i could press the arrow buttons. The feeling was amazing, more better and nicer than my actual membrane keyboard. So what i need to know, those Khali Razer green switches are equal with what cherry mx color ? And there is something with better feeling like this one ?
Thank you again,
https://linustechtips.com/topic/393315-switches/
cherry mx blue
https://linustechtips.com/topic/393315-switches/#findComment-5307698
I still would recommend a Cherry MX keyboard. I would recommend cherry reds, but blue's are nice as well.
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/393315-switches/#findComment-5307709
Yes, i will choose a cherry mx switch, but i need to know, razer green switches are similar to mx blue like @spwath said ?
Yup they are both clickey switches.
They feel identical from my comparison, with the razers just being lower quality.
But the MX blues are the razer green equivilent, and the mX browns are the razer orange equivilent
https://linustechtips.com/topic/393315-switches/#findComment-5307838
https://linustechtips.com/topic/393315-switches/#findComment-5311287
