I'm running out of storage space and I'm so cash tight right now to the point where I cannot afford 2x HDDs for RAID 1 at the moment. I'll have to settle for 1 HDD for the time being and hope that the HDD is reliable enough not to fail and lose my data. Which is the most reliable consumer-grade HDD right now?
CoolerMaster CM 690 II Basic | Intel i7-2600 | CoolerMaster Hyper 212+ 2x Zotac GTX 1070 AMP! Edition
Asus P8Z77-V LK | 2 x 4GB Kingston HyperX DDR3 1600MHz CL9 | SeaSonic M12ii 850W 80+ Bronze Crucial M4 128GB
https://linustechtips.com/topic/39309-most-reliable-consumer-grade-hdd/
Most reliable? Completely up for debate and no conclusive answer.
You want a reliable and good performing hdd for cheap? Seagate barracuda.
WD vs Seagate debate inbound.
both manufacturers have NAS drives, these are designed to run 24 hours and to be reliable.
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
If you'll be putting two HDDs in RAID eventually then go for WD Red drives.  If you aren't then WD Green drives are good, so are Seagate Barracudas.
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
I just let go of my old Samsung Spinpoint F3 1TB which lasted me 6 years. Still going strong and is in my mums computer now. It was also quite quiet compared to the Barracuda I have right now if that's an issue.
Wit is educated insolence.
