Hi, Im not sure where to put this sub forum but my computer has 8GB of RAM and when its idle it is using 75-80% of it. Task manager show that Service Host: Local System is usong the most but thats only 99MB. I also got an error saying "Only part of a ReadProcessMemory or WriteProcessMemory reques was complete" when I opened task manager. I am running windows 8.1 64bit on an AMD A8 6500.
=Update=
Quite literaly actually. It just restarted on its own [emoji14] 15 Min after I put it to sleep.
https://linustechtips.com/topic/392771-memory-problem/
Best way to check for any hardware issues would be to Download and run Memtest, That will at least give you the knowledge if it is a hardware failure.
CPU  Intel i7 5820k Motherboard Asus X99-S  RAM  32GB (8x4) Kingston Hyper X Fury GPU EVGA GTX 1080Ti SC2 iCX Case Fractal Design R4 Windowed Storage 500GB Samsung 850 Evo + 120GB Crucial M500 SSD + 2TB Seagate Barracuda + 1TB Western Digital Blue PSU Corsair RM1000 Display 2x Asus VS239HV Cooling  Noctua NH-D15 Keyboard  Corsair K70 RGB Mouse Logitech G502 Gaming Surface Razer Golitahus Extended Speed
https://linustechtips.com/topic/392771-memory-problem/#findComment-5300688
