I am building this system:
PCPartPicker part list: http://pcpartpicker.com/p/Pkr83C
Price breakdown by merchant: http://pcpartpicker.com/p/Pkr83C/by_merchant/
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  (Purchased For $50.00)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  (Purchased For $10.00)
Memory: A-Data XPG V2 8GB (2 x 4GB) DDR3-1866 Memory  ($57.99 @ Newegg)
Video Card: XFX Radeon R9 280X 3GB Double Dissipation Video Card  ($229.98 @ Newegg)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($37.99 @ NCIX US)
Total: $385.96
Generated by PCPartPicker 2015-06-23 00:34 EDT-0400
I have everything in and when I put my screw driver on the power pins on the mobo nothing happens. I have tried a different psu and nothing. I tried without a video card and woth different ram and in a dfferent slot as well. Nothing works.
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
https://linustechtips.com/topic/392104-no-post-at-all-help/
Total: $385.96
Did you make sure to plug in the CPU plug from the power supply ? Also check if this motherboard needs an update for that CPU.
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/392104-no-post-at-all-help/#findComment-5292123
Yes. It does not.
https://linustechtips.com/topic/392104-no-post-at-all-help/#findComment-5292427
