Its pretty good. Its a very good case. The only downside is its heavy and doesn't support all atx psus. Look up whether yours is supported. Your other option for black and green is any black case with some led fans - cooler master sickle flows are very cheap and good for the price although far better fans do exist
i3 4170 : Asus R9 270 : MSI h81M-Pro VD : Cooler Master Hyper TX3 EVO : Seagate Barracuda 1TB : NZXT Source 210 : Some Random RAM
https://linustechtips.com/topic/391815-case-input/#findComment-5288479
I have the red/black one and I truly recommend it. It's sexy as hell. My temps are decent, can check if you request it. Nice and easy cable management too. One downside is that you have no place for a cd-drive but hey, it's 2015.
https://linustechtips.com/topic/391815-case-input/#findComment-5289293
yeah screw the cd-drive xD I another computer anyways
https://linustechtips.com/topic/391815-case-input/#findComment-5289692
