Hi Guys and Gals,
So over the last few months I've been having a serious issue with my PC and can't seem to isolate the issue.
Basically, my PC shuts down (completely looses power) without warning or BSOD after 30 minutes of being on. I have check windows event viewer and couldn't see anything out of the ordinary
I've run various tests on individual components with no luck.
Any help or advice would be much appreciated.
So far I have:
  • Replaced the PSU
  • Stress tested CPU, GPU and Ram. Programs used, Furmark, OCCT and Mem Test (Temps were in a normal range)
  • Tested PC withiout GPU, using built in MoBo graphics
  • Left running in Bios mode
  • Replaced Cmos Battery
I know I probably haven't done as much as the average nerd would but I'm still fairly new to the custom build world.
Specs:
GPU: Gigabyte GV-N760OC-4GD
CPU: Intel 4770K
PSU: 650W Cooler Master V-Series 650S Gold
MoBo: Asus Maximus VI Impact
Cooling: Cooler Master Seidon 120XL Water Cooling Kit
RAM: 2x4GB G.SKILL Ripjaws 1600MHz DDR3 Ram
https://linustechtips.com/topic/391326-help-pc-keeps-shutting-down/
Did you make sure everything is plugged in correctly?
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
