From A4 6300 -> Athlon x4 860k
Everything works great in terms of gaming performance, but seeing
1.sudden black screen that takes a couple of seconds and comes back to normal
2.Sometime the whole pc just gets extremely slow, and freezes, well my hdd is working its ass off from the hdd led but things get really choppy
-I already have all the latest drivers
-No, i have all my registry and junk file clean, it even happens when i switched hdd and ran ubuntu 12.04(not sure of the version)
-I didn't face these issues before upgrade
-My thermal is good, motherboard and every other component works fine, well atleast from what I can see
*Troubleshoot might have been better thread, sorry, replace if you want to*
https://linustechtips.com/topic/391233-having-problems-after-cpu-upgrade/
Do you have a GPU to go with that Kaveri?
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
Yeah, R9 270, so far haven't seen any issue, when i tried it out with different cpu never had that black screen moment
Are you sure your monitor is plugged into the R9?
EDIT: Try updating your BIOS.
ofcourse man, athlon doesn't have any intergrated gpu how am i gonna get display if i dont
Bios is up to date
Just making sure. Sometimes the best of us make the dumbest mistakes.
It might be overheating... What's your cooler?
stock fm2, the one that comes with it, same goes for the thermal paste
Any OCing?
No
What are your temps?
sorry took me awhile, had to restart to get the temps, around 40, probably went up to 60 at most when gaming, i don't really have extremely demanding games, most of my games are like 2010 ish and or source engine
Also do appreciate your eagerness to help
What's your MOBO? RAM frequency? Have you tried switching PCI-e slots?
make sure no old drivers are still installed. Ususaly when going with a new cpu, a clean install is what i would recommend.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
sorry if I am coming off stupid, but there are cpu drivers? never knew
not really, but any old motherboard drivers may still thing you have the other cpu, so reinstalling all of them would be a good idea.
There are drivers for the 6300 you had. Those could definitely interfere with the functioning of your 860K
only had one dual core optimizer that was given to me through Batman Arkaham Asylum and not only reinstalled that game also that program, nothing helped so far :(
